Hello guys,
I have a doubt about Direct Play on WebOS LG SmartTV. I tried a lot of movies with different containers, but in ALL cases plex is transcoding the container.
It looks like It just accept a format MPEGTS. What becomes Impossible to plays any movie in Direct play. Is that right?
SE56
May 30, 2020, 12:57pm
2
If I understand this correctly, you need to change your LG WebOS Plex client quality to (Original).
It’s already. I change everything to original in settings.
SE56
May 30, 2020, 1:00pm
4
Can you please outline your set up of your network, Versions, OS, WiFi or Ethernet
I use Windows 10. The notebook where runs the server is on cable Ethernet. The TV is on WiFi.
Versions of what?
SE56
May 30, 2020, 1:08pm
6
Server version, Plex LG Client version. You will find these in the server settings Authorized devices
Oh, right.
Server version: 1.19.3.2852
LG Client Version: 4.29.6
Android Client Version: 6.1.3.933
On Android it doesn’t happens. It direct plays a lot of movies. Even the container. Different from the TV.
SE56
May 30, 2020, 1:15pm
8
I own a LG OLED and exclusively use mkv without any issue
Yes, when I put it in a Pendrive, it plays mkv without any issue. But in Plex it transcodes, Idk why.
SE56
May 30, 2020, 1:17pm
10
Do you know were the settings for plex are on your TV
I didn’t understand. The setting of Plex on my TV?
SE56
May 30, 2020, 1:21pm
12
Yes, do you know how to navigate to them on your TV
Yes, I already configure it. I put everything on Original in the Quality settings.
SE56
May 30, 2020, 1:22pm
14
Audio and video settings?
SE56
May 30, 2020, 1:25pm
16
So has this just happened or has it always done this?
I configured it past 2 days. I already tried after configure it, but, it keeps happening the transcode.
SE56
May 30, 2020, 1:27pm
18
So this is a new configuration using Plex?
Have you tried using The server Dashboard. Click to enlarge
transcoding issues. Can you please vote for it to have it implemented? This way your issue gets fixed too!
Plenty of issues all arround the web regaring transcoding with SmartTV Plex clients. My suggestion is simple:
Create an option in the server settings - Authorized Devices to override the default audio , video codec settings and support for a specific device. This way a plex admin can influence if a stream get transcoded or not. Plex can collect the information and use this to improve the defaults in plex profiles for future released of plex media server based on client/brand/model/app.
If the …
