Matching Agent Fails Immediately
Server Version#: 1.40.1.8120
Player Version#: 1.87.2.87-87488d5a
I have a smart playlist of music that is “unmatched” so I can clean some of these more obscure cds. Anyway, prior to this latest update, the match feature at least tried to return a result. Now after choosing match, the pop down already says no matches found. These two entries immediately show in the log file:
Feb 23, 2024 08:48:29.252 [0x700006da8000] ERROR - [Req#80c/MetadataAgent/tv.plex.agents.music] Error parsing content.
Feb 23, 2024 08:48:29.252 [0x700006da8000] ERROR - [Req#80c/MetadataAgent/tv.plex.agents.music] Error parsing XML: Error parsing file.
Anyone experiencing with the latest beta?
TIA
I also tried to add a new movie and it would not play. I reverted back to 7998 and everything has begun working properly again.
Just updated to 1.40.1.8173 and music matching still immediately fails with this window.
Reverting back to 7998 resolves the issue. Not sure what I can do to assist with its resolution.
Server logs would be required.
When running version 8120 and now 8173, when I choose match or fix match for an album, there are the only two entries placed in the Plex Media Server log file.
Mar 07, 2024 09:53:14.982 [0x700006195000] ERROR - [Req#2ba/MetadataAgent/tv.plex.agents.music] Error parsing content.
Mar 07, 2024 09:53:14.982 [0x700006195000] ERROR - [Req#2ba/MetadataAgent/tv.plex.agents.music] Error parsing XML: Error parsing file.
Plus there is NO activity in the Plex Media Scanner Matcher log file.
When running 7998, when I choose match or fix match, there is no relevant data in the Plex Media Server log file but there is this data in the Plex Media Scanner Matcher log file:
Mar 07, 2024 10:19:39.312 [0x70000bfbe000] INFO - Plex Media Scanner v1.40.0.7998-c29d4c0c8 - Apple MacBookPro8,2 x86_64 - build: darwin-x86_64 - GMT -05:00
Mar 07, 2024 10:19:39.313 [0x70000bfbe000] INFO - MacOSX version: 10.13.6, language: en-US
Mar 07, 2024 10:19:39.313 [0x70000bfbe000] INFO - Processor: 8-core Intel(R) Core™ i7-2635QM CPU @ 2.00GHz
Mar 07, 2024 10:19:39.313 [0x70000bfbe000] INFO - /Applications/Plex Media Server.app/Contents/MacOS/Plex Media Scanner --match --type 8 --log-file-suffix Matcher --item 78387 --match-tag-mode=exclusive
Mar 07, 2024 10:19:39.463 [0x7fff95108380] WARN - [FFMPEG] - Estimating duration from bitrate, this may be inaccurate
Mar 07, 2024 10:19:39.464 [0x7fff95108380] WARN - [FFMPEG] - Estimating duration from bitrate, this may be inaccurate
Mar 07, 2024 10:19:39.466 [0x7fff95108380] WARN - [FFMPEG] - Estimating duration from bitrate, this may be inaccurate
Mar 07, 2024 10:19:39.467 [0x7fff95108380] WARN - [FFMPEG] - Estimating duration from bitrate, this may be inaccurate
Mar 07, 2024 10:19:39.467 [0x7fff95108380] ERROR - [Time] Date looks invalid: 1968–1–1
Mar 07, 2024 10:19:39.470 [0x7fff95108380] WARN - [FFMPEG] - Estimating duration from bitrate, this may be inaccurate
Version 7998 does return useful matches for the musical album being matched, so something after 7998 seems to be broken. I don’t think my agents config is incorrect as it doesn’t change between 7998 and 8120 and beyond.
First make sure you replicate the issue on your end first, then go to the link: Server Logs
Take that zip file you get and upload it to this thread.
