Matching Issues with several shows
Ran into something that is unusual for me.
I have 2 shows that for some reason won’t match and running “Match…” brings up entirely wrong shows. There doesn’t appear to be a way to force it to sync with the correct show.
The shows are:
9-1-1
The League
Ironically 9-1-1: Lone Star matched up just fine. I have over 60 shows, and these are the first 2 I’m having issues matching up. Any ideas here?
Also why can’t we add an TheTVDB number anywhere?
From the main show page, pick “Match” or “Fix Match” on the drop down menu. It will default to the Auto Match tab. Click the Search Options tab and paste the TVDB number into the title field over top of the name that is likely already there. Click search and you will find it. I do this all the time and it works, including yesterday for the 9-1-1 show you mentioned.
As for why it suddenly stopped matching, guessing it has something to do with the recent EPG change. I’m also having a number of shows not matching as well, including 60 Minutes. But the process I described always fixes it for me.
Hot damn! Thanks.
No problem. Something I picked up from another kind soul’s answer to someone else’s question.
