Matching nextgen virtual channel #
Server Version#:
Tuner Make/Model: HDHR flex4k
Guide/Lineup name: York Pa broadcast
Using XMLTV?:
Channel number/Name: 227.1 WHTM
I’m not having any success with mapping the Nextgen broadcast of WHTM. the plex server sees the channel as 227.1 from the flex4k when I try to match it with the listings for 27.1 which is the 1.0 broadcast its a copy of I get an error message that there were errors and It won’t allow me to save the line up with it matched like that.
I have found that if I matched 227.1 to WMAR 2.1 from the nearby baltimore market ABC station it wall save and allow me to view that broadcast in PLEX however the guide data is only then accurate during the time ABC national network shows are on.
Is there a fix for this?
