- Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3 7.0.3 (6917)
- The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.123
- The local IP address of the device that PlexConnect is installed on: 192.168.1.123
- The device and operating system (including version number) that PlexConnect is installed on: Dell Laptop Windows 8.1
- The device and operating system (including version number) that the Plex media server (PMS) is installed on: Same. Dell Laptop Windows 8.1
- The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.11.7.803-87d0708
- The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.123
- The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork. Plexconnect 02/23/2015
- The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect]
enable_plexgdm = False
ip_pms = 192.168.1.123
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = Normal
logpath = .
Log file: http://pastebin.com/hukx7kgm
Almost have everything working, but a handful of files are not playing. Initial installation I was using Plexconnect over wifi so I could be close to the ATV for troubleshooting. In the Settings.cfg ip_pms = 192.168.1.124 for wi-fi; it is now ip_pms = 192.168.1.123 with the ethernet cable plugged in. While over wi-fi 1 movie file and 1 tv file were tested and played without any issues. Now over ethernet it seems like every file works except for these 2 (and 1 more... see below) that were tested over a wi-fi connection. The loading symbol spins for some time and then an error message appears saying it cannot play.
Furthermore, there is actually one other movie file that does not play. The TV used is an LG smart TV with Plex. This other movie file started playing using the LG smart TV software, but there were issues selecting the correct subtitle file. This other movie file was not tested with plexconnect over wi-fi, only plexconnect on ethernet. It brings up the same error as the other 2 video files.
Please advise and let me know if more information is needed. Thank you in advance!
