I am having a problem where my Plex server is not combining two of my libraries on my home. Specifically, I have a 4K TV Shows library and a Youtube Library. Both libraries are “TV Shows” libraries. My other TV Show library and Anime TV library are merging on the home correctly. All of my libraries on the Manage Recommendations tab are set as the following screenshot.
The only significant difference between these two libraries are the Scanner and Agent.
So the question is, does the scanner and agent need to be the same for the libraries to merge correctly? Or am I just experiencing a very strange bug?
–EDIT–
Forgot to mention, in the past all of these TV Shows libraries merged correctly on the home screen. Even after the major change to the home screen with manage recommendations.
I posted this same topic on the r/PleX subreddit: https://www.reddit.com/r/PleX/comments/oz78az/plex_merge_recently_added_items_not_functioning/
No one there seemed to have any ideas either.
