Hey, I just got another netflix show added…but the wrong meta data is being applied.
In stead of the episode name it shows: Netflix followed by the release date and time.
Anybody know how to correct this? manual edit takes a long time.
Do check if your files are in mp4
/m4v
format.
If they are, they could contain internal metadata which can potentially throw off Plex’s scanners or overwrite the episode names Plex fetches from TheTVDB.
To avoid such troubles, go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Afterwards, Plex Dance the affected episodes.
I’m gonna try it out, Thanks for the reply
