Is anyone else having issues getting Metadata to download for TV Series: Motherhood?
Are you talking about âIn the Motherhoodâ from 2009?
https://www.thetvdb.com/series/in-the-motherhood
Edit:
added a test file <tv show root>/In the Motherhood/Season 01/In the Motherhood - s01e01.mp4 â matched and downloaded all metadata right away.
If it ainât there - it ainât there.
If it is there - which one is it?
Iâm so very sorry. I mis typed. It is Motherland: Fort Salem.
That worked instantly and perfectly only a moment agoâŚ
If you have MP4/M4V files - after you do ^that^ - do this:
Then âRefresh Metadataâ at the Show Level.
Not getting art work or info from TVDB. I have tried your suggestion and I thank you. This is the only TV series Iâm having issues with.
Try this first:
https://support.plex.tv/articles/202967376-clearing-plugin-channel-agent-http-caches/
Then - in desperation - Do this with the whole show:
All steps, in order - or it wonât work.
