Metadata help please
Server Version#:current
Player Version#:current
normally i use mp3tag to remove meta info on TV shows i forgot to do that. i did do it after plex found the show how do i make plex forget what it found and have it find the right meta info from thetvdb?
Force a new discovery of previously misidentified/mislabeled material due to bogus embedded metadata in MP4/M4V files:
To prevent Plex from reading embedded metadata in MP4/M4V files, preventing the issue you are having entirely…
The 4th paragraph is the answer:
Note: if you do this step first, then refresh metadata for the whole show, or a single movie, it’s possible the issue will resolve. Worth a try.
Note: this issue will present for TV Shows and Movies, so moving Local Media Assets to the bottom of the stack for every agent (where applicable) would be wise.
