Plex Media Server Version#: 1.13.9.5439
FreeNAS Version#: FreeNAS-11.2-RC1
I recently upgraded from FreeNAS 11.1-U5 to 11.2-RC1. I also installed a new PMS plugin using the new iocage in 11.2. I was able to copy the “Plex Media Server” folder from ./jails/plexmediaserver/var/db/plexmedia/ to ./iocage/jails/plex/root/
After I set it up and ran it, everything seemed fine. All my movies and TV Shows were there and everything streamed and transcoded on my LAN and over the internet. So, I deleted the only PMS.
However, when I went to add some TV and Movies, PMS now refuses to find any matches for the movies and TV shows. It doesn’t matter is I manually search for them or try to auto match.
I have deleted the movies, rescanned the library, clean the bundles, re-added the movies and re-scanned. No change. I have refreshed all the metadata and still no change.
Please tell me you can help and that I didn’t just screw myself over…
Plex Media Server Logs_2018-11-18_00-27-50.zip (2.0 MB)
Solved: I just started from scratch. I reinstalled a new plugin and did not try and import my old database. I just am going back through and making my custom changes again.
