Metadata not updating for Movies
I’ve had a plex media server set up on Raspberry Pi 3 for about a year. About 3-4 months ago I had to reinstall plex and rebuild my library. Since that time I can’t get metadata for Movies, but it works fine for TV Shows. I’ve gone through any documentation I can find, but have been unable to resolve this. Any thoughts or experience to share on this is welcome.
You could attach logs - maybe we can spot the problem in the logs. Use the built in function to grab all the logs - Settings> Server> Help> Download Logs.
To make troubleshooting the logs easier, you should:
Make sure that debug logging is enabled (Not Verbose)
Quit Plex Server
Give the server 1 minute or so to properly shutdown
Start Plex Server and give the server 3 or 4 minutes to perform start-up tasks
Bring in a new media item or perform the Plex Dance on an existing item.
Make sure that you aren’t doing anything else with the server during this test!
Wait a few minutes and grab log files and attach them to your next post.
Reporting issues with Plex Media Server
Thanks for the follow up, astrofisher. I’ve attached the log file here. I’m not sure what I’m looking at, but am guessing it’ll tell you something.
That’s the web app log - it doesn’t help here. Need to take a peek at the server logs. Re-read my first post.
Ah, yes, my fault. The log zip file is attached here.
Those logs are from November of last year. :o
Yeah, the date definitely points to that. However, when I type ‘date’ on the Pi, it returns ‘Fri 11 Nov 22:01:10 MST 2016’. This tells me that, while the Pi needs to have the date corrected, the logs are likely current.
Then you have a very likely reason for your issue:
  • communication with the metadata servers is encrypted
  • encrypted communication needs correct time stamps on the network packets, or they are getting discarded at the receiving side, no prevent “replay attacks”
  • if your Plex server doesn’t have the correct date and time, it cannot communicate over encrypted connections. Big parts of Plex’s functionality will fail in this case.
Well, there you go. I updated the time/date on my Pi and rebooted. Now when I go to fix incorrect match, it works like a charm. Thanks to both of you, astrofisher and OttoKerner, for the assistance. Plex is happy again…
