This has been on tmdb for a few weeks but can’t be found in Plex Movie matches: https://www.themoviedb.org/movie/1621112-long-distance-calling-live-at-lichtburg
Regards,
Gary
Regards,
Gary
Do you know what the age rating of the Bluray is?
At this moment there is only a UK release information with no age rating. I assume that this might have an influence on the availability per API.
If it’s a German release, you’ll find a big ugly button on the disc and/or the cover. Here are the possible varieties listed: Freiwillige Selbstkontrolle der Filmwirtschaft - Wikipedia
I assume that the rating is not “18”, so it won’t be treated as adult content.
I think if this is added as the german age rating, it may help availability.
On that TMDB page, its listed as Music, not Movie. Is that going to cause a problem?
No, I have many concert videos myself, which are listed that way.
I don’t see a imdb link and cannot find it listed on imdb. Doesn’t plex require a movie to have an imdb entry which can then be linked to the one on tmdb ?
I could be misremember this requirement but it might explain why its not coming up …
I don’t think so. I have a few which are not listed on IMDb either, and they work alright.
I copied a dummy file into my Movies folder named just like the TMDB page has it listed. I shows up but is not matched to anything. I tried doing a fix match with the TMDB id, it says nothing found. Something seem odd.
That’s what OP has reported.
I know, I was just trying to verify that it wasn’t just something he was doing.
