MKV Dolby Vision 07.06 Stopped Playing Since 8.13
Server Version#: 1.22.2.4282
Player Version#:8.15.1.23935
Since version 8.13 Dolby Vision files stopped playing back on my Philips TV 65OLED934/12 running Android TV Pie. The files I’m trying to playback are MKV with DV Profile 07.06.
Everything works fine with version 8.12.2.22756, but as soon as I update Plex app won’t play any DV mkv file.
Please help me.
Any ideas guys?
Fyi, on 8.16 dv 07.06 in mkv is still broken
same thing with me. since version 8.13 plex doesn’t play any DV video on my dv-capable tv anymore
Finally, I’m not the only one!
No ideas or solutions?
For me is sticking to old version and if things still don’t work after a while, I try something different. Jellyfin seems to be promising, have to check it out. Thank god I haven’t purchased plex pass yet.
Fyi, 8.17.1.25326 doesn’t work either
+1 for me. Only HDR as if recent update.
Yep, I’m just tired trying every new version and then revert back to the old one. It’s so annoying.
This is resolved for me as of 8.18.1
Nope, v8.20.0.26605 still the same issue. This is ridiculous!
Have you tried to set the passthrough setting to optical and then uncheck ac3 under optical codec setting. See if it works.
Well, at least I got playback with this setting now, but it still doesn’t trigger dolby vision only basic hdr.
Also it now transcodes dts and ac3, which is bad, because my tv supports both. With 8.12 everything works fine
The support stopped exactly at 8.12.3!
With 8.12.2.22756 everything works fine. I just don’t get it why it was dropped.
Please fix Dolby Vision from MKV!
Guys, pelase fix it. It’s just ridiculous, that we have to use the old version of plex to play those files properly
Ok here we go again:
8.23.1.28053 - still NO DOLBY VISION!
Update:
I’va managed to run profile 7 with plex Version 8.26.0.29181.
Here’s the workaround:
  • Start the movie woth TrueHD Atmos track, witch will transcode to ac-3, as unsupported and the the video will fall back to just hdr
  • pause the video
  • switch audio track to something like dts or e-ac-3 and the the dolby vision will be triggered
With newer vesrions like 8.28.0.29906 ist isn’t working anymore. Not sure what the doing there, it’s just so frustrating
Ok guys, I think v8.29.1.30697 ist tje worts right now.
Profile 7 the dts tracks aren’t supported and even Profile 8 jumps to a AC-3 when I select a DTS track without warning. Also Ac3 + Atmos is dropped completely. What’s going on?
