Mkv Filme
mkv Filme werden verzerrt ausgegeben.
bei mir nicht.
hm ok
Bissl mehr Informationen wÀren nicht schlecht:
  • wo? Computer, Handy, tv?
  • alle Filme?
schönen Gruß
Mach bitte einen Screenshot.
Dann poste dazu den Inhalt des Plex XML info dieses Videos.
Server Version#: 1.15.4.993
Android TV Player Version#: 7.14.1.9954
Auf allen anderen Devices (PC, iPhone, iPad) ist das Bild normal.
Das Problem tritt bei allen .mkv Filmen auf
Hier die Plex XML info
<?xml version="1.0" encoding="UTF-8"?>
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="8" librarySectionTitle="Filme" librarySectionUUID="93f3b540-23ef-4272-b9e1-8b01927d68b8" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1555951837">
<Video ratingKey="29856" key="/library/metadata/29856" guid="com.plexapp.agents.imdb://tt8155288?lang=de" librarySectionTitle="Filme" librarySectionID="8" librarySectionKey="/library/sections/8" studio="Blumhouse Productions" type="movie" title="Happy Deathday 2U" originalTitle="Happy Death Day 2U" contentRating="FSK 12" summary="Als..." rating="5.8" viewOffset="525001" viewCount="1" lastViewedAt="1556274443" year="2019" thumb="/library/metadata/29856/thumb/1556200972" art="/library/metadata/29856/art/1556200972" duration="5993278" originallyAvailableAt="2019-02-13" addedAt="1556200919" updatedAt="1556200972" primaryExtraKey="/library/metadata/29857">
<Media id="68286" duration="5993278" bitrate="5144" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="ac3" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" videoProfile="high">
  <Part accessible="1" exists="1" id="68458" key="/library/parts/68458/1556131350/file.mkv" duration="5993278" file="/volume1/NAS/Medien/Filme/Happy Death Day/Happy Death Day 2U (2019)/Happy Death Day 2U (2019).mkv" size="3854956627" container="mkv" deepAnalysisVersion="3" requiredBandwidths="9308,7632,7632,7632,7632,7632,7632,7632" videoProfile="high">
    <Stream id="153445" streamType="1" default="1" codec="h264" index="0" bitrate="4537" language="English" languageCode="eng" bitDepth="8" chromaLocation="topleft" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="800" level="40" profile="high" refFrames="5" requiredBandwidths="8699,7095,7095,7095,7095,7095,7095,7095" scanType="progressive" width="1920" displayTitle="1080p (H.264)" />
    <Stream id="153446" streamType="2" selected="1" default="1" codec="ac3" index="1" channels="2" bitrate="223" language="Deutsch" languageCode="ger" audioChannelLayout="stereo" requiredBandwidths="224,224,224,224,224,224,224,224" samplingRate="48000" displayTitle="Deutsch (AC3 Stereo)" />
    <Stream id="153447" streamType="2" codec="ac3" index="2" channels="6" bitrate="384" language="English" languageCode="eng" audioChannelLayout="5.1(side)" requiredBandwidths="384,384,384,384,384,384,384,384" samplingRate="48000" displayTitle="English (AC3 5.1)" />
    <Stream id="153448" streamType="3" selected="1" default="1" forced="1" codec="srt" index="3" bitrate="0" requiredBandwidths="1,1,1,1,1,1,1,1" title="forced" displayTitle="Unbekannt Erzwungen (SRT)" />
  </Part>
</Media>
Also, deine Videodatei hat die Abmessungen 1920 x 800 Pixel. SeitenverhÀltnis 2,4
Das ist bei Cinemascope-Filmen durchaus ĂŒblich.
Dein Screenshot zeigt aber eher ein SeitenverhÀltnis von 3,0.
Zeigt sich dieses Verhalten auch auf anderen Plex-Clients, oder nur an deinem TV?
Hat deine Fernbedienung eine ‘Aspect’ oder ‘Zoom’ Taste?
das Problem ist nur am Fernseher und auch erst seit einer Woche.
Ca. in diesem Zeitraum wurde die App aktualisiert.
Leider ist das Àndern des Bildformat in PLEX nicht möglich.
Des weiteren werden mp4 Dateien korrekt wiedergegeben.
Habe eine Rubrik Serien. Komischerweise passen da sogar die mkv Dateien
Kannst du bitte mal die Mediainfo der MKV Datei mit diesem Standalone-Tool auslesen?
download mediainfo here
(pay attention during installation, it comes with a ‘piggybacked’ installer which asks to install additional crapware. Make sure to set/clear the right checkboxes!)
Once it is installed, analyse the file, then go to:
File - Export - Text (Advanced mode)
MediaInfo.txt (5.7 KB)
Kannst du mal einen Film raussuchen, der das volle Format 1920x1080 Pixel hat? Tritt das Problem dort auch auf?
Dort tritt das Problem nicht auf
MediaInfo.txt (5.0 KB)
Jo, das erklÀrt warum es bei Serien nicht auftritt. Cinemascope kommt bei Serien praktisch nicht vor.
Kriegst du das hin, ein kurzes Beispielschnipsel zu erzeugen?
https://support.plex.tv/articles/201035968-generating-sample-files-from-media/
ok. ist erstellt. was soll ich damit machen?
Auf GDrive hochladen, freigeben und mir den Link schicken, bitte.
[moderator edit: link removed]
Danke!
Hast du geprĂŒft, ob der Schnipsel genauso verzerrt angezeigt wird?
Welcher Typ ist dein Fernseher genau?
ja ist auch verzerrt.
hab einen Philips OLED mit Android 8
