I saw in the docs that there is a “More” button to search for subtitles manually. It does not appear on my plex web app version 1.14.0.5470. I enabled the OpenSubtitles agent and gave it my login and password.
That depends on the version of Plex Web you are using, not the server. The version of Plex Web bundled with PMS is a bit behind. Use the hosted version of Plex Web at https://app.plex.tv/web/app.
Ah! Yes, indeed, the version at https://app.plex.tv/ has the option while the http://localhost:32400/web one does not. I thought they were the exact same thing (with redirection magic or else).
Thanks for pointing this out
