Not sure if I am posting in the right forum, and also this is kind of hard to explain. When I add a movie it is listed twice in my library. It list it once and says 1 movie under it then it list the movie again with a year under it. Is there a way to turn one of these off? It’s really annoying to me.
Sounds like you have clicked on ‘collections’ at some point: that lists all movies and also groups them. I can’t seem to turn it off either. If you select ‘sort by year’ or one of those options, it might hide it (works for me).
Nice if it was actually fixed (as in worked as expected).
When you said what it was “Collections” I figured it out. If you go to where your library is, you will have to do it for each library. Hover over it with the mouse (PC) and 3 dots appear (…) click it and select edit. Then click on “Advanced,” go down and you will see “Collections” with a dropdown box. Select “Disabled” and that should fix the problem. I just didn’t know what it was called lol.
