Movies not loading - wont stop buffering
Server Version#: 1.41.3.9292
Player Version#: 4.142.2
Im using an old Dell optiplex as my server. its been working fine for a year until this weekend. My dad texted me and said the server was down. i logged in on my phone and everything was there so i figured it was fine. He texted me again and said it was still down. I can access my Library from any device (Phone, Xbox, PC, Roku) but nothing will load. I updated the server Friday night and didn’t check to make sure it was working. Steps ive tried:
-reboot server
-disconnect and reconnect the network
-check network devices for driver updates
-uninstall and reinstall Plex media server
Im still pretty new at this so any guidance what to do next would be much appreciated.
Update before post: Dad texted again and said he can only watch the older movies on the server, but nothing i have recently added. i have confirmed this myself.
Update: i have been able to determine that only HD videos will play (anything i added from a blu-ray) anything lower quality from a DVD will not load or play
Can you post a copy of your server logs?
Plex Media Server Logs_2024-12-16_17-28-37.zip (4.5 MB)
Attached - Thank you!
I am seeing a LOT of errors similar to:
Dec 16, 2024 16:57:21.705 [4048] ERROR - [Req#1b9129/Transcode/77833b9b-2945-436c-9440-4e288706fe4f-238/ca9cb8df-a22f-49b6-bec8-e3a9a26f368a] [mpeg2video @ 0000024f2538a740] hardware accelerator failed to decode picture Dec 16, 2024 16:57:21.705 [4048] ERROR - [Req#1b912a/Transcode/77833b9b-2945-436c-9440-4e288706fe4f-238/ca9cb8df-a22f-49b6-bec8-e3a9a26f368a] Error while decoding stream #0:0: Operation not permitted
Can you stop Plex and then rename %LOCALAPPDATA%\Plex Media Server\Codecs to %LOCALAPPDATA%\Plex Media Server\Codecs.old Then restart plex
I think I did it correctly. Plex restarted now it says app.plex.tv is unable to connect to server securely
What happens when you visit http://127.0.0.1:32400/web from the server?
It was able to connect again after going there. Videos still not playing
It working from the mobile app but any other device still refuses to play
Can you post a fresh copy of your server logs ? want to see if that fixed that error?
Plex Media Server Logs_2024-12-16_18-31-04.zip (2.2 MB)
That error is FLOODing your logs. Can you go to server settings => Transcoder and disable Use hardware acceleration when available then restart the server and see if that does anything?
Well i don’t know what that was on, i don’t even have a graphics card in my server. That was the issue and everything is working again.
Thanks for the help!
