I am running the latest PMS on Windows 10 on a Core i7 4790 and watch on a Samsung 2017 Smart TV
When I watch a movie with DTS audio (AC3 is no issue) every few minutes the video freezes for a split second (probably 0,5 to 1,5 seconds) but the audio plays fine during this time.
I restarted PMS to get fresh log files and watched a little bit Avengers Endgame. Around the 19:54:50 mark (+/- 10 seconds) there should be a big “freeze”, I hope you can see something in the logs.
Same issue here. Picked up the Samsung 70" UHD during the Best Buy pre-Black Friday deal. Plex for Samsung 4.5.1 (latest available). Maybe 1/2 a dozen times during a movie, video will freeze for 2-3 seconds while audio plays fine, then video will “catch up” and continue.
It was mentioned in another thread to disable Direct Stream, basically forcing it to transcode even when unnecessary. This did not work for me; issue persisted whether both Direct Stream was checked or unchecked, or whether Direct Play was checked or unchecked.
I have the same problem. The pictures freeze 1-2sec,but the audio still run. I tried 3 Samsung tv with Tizen, and for 1-2 months ago got this problem. I tried reinstall, but doesn’t work. This is only happening when i use transcoding, direct play is fine.
Can someone confirm the specific workaround for this? Ive gone into settings, and tried direct play and direct stream checked, both unchecked, and each checked individually. Still frequent pausing. Are there other settings that need to be set?
I am experiencing the same issue with a Samsung TV (Tizen 4.0, Plex 4.5.1). I also run Plex on an Apple TV, Vizio TV, and even a PS4 connected to the Samsung all without issue. The video only freezes when using the Plex app on the Samsung TV with DTS audio. I saw in other posts that a Plex version 4.11.x is available. Does this fix the video freeze?
Well for me that bug has been there since I started using Plex, and its still there, so I take things into my own hands. If your prepared to wait, then its not a solution.
Might be out of the woods on this issue, but looking to others to confirm. As of Plex for Samsung app version 4.19.2, I watched 2 full length movies with DTS audio track and did not see a single stutter or delay.
