If this is not in the right place I apologize. I understand that one of these issues would be hard to fix. Despite this, it really is a feature that the end users need on this specific device: The ability to utilize continuous playback with the Roku. It kills me that both myself and my parents have to manually view each episode one by one, and numerous people here have requested it be added as well. I acknowledge that the Plex developers are hard at work, and commend them on all they’ve done with the recent updates. However, I implore them to look into this again.
The other issue is a much simpler one: The ability to change the TVDB order from Aired Date to DVD Order natively. A user should not have to meddle with plugins just to set up the shows they’ve bought. To simply choose a series in the server that they want to change, and edit it’s settings to be listed as they wish. Not that this is necessarily Plex’s fault, but the option to switch between the two pages of data should be easy enough to add.
Thanks in advance!
Correction, there is one last thing I’d like to add. Currently - at least on Android - there’s a bug where saved media servers will get overwritten by whatever it finds nearby. This needs to be fixed. I have two server entries, one for home and one for when I’m out (LAN/Internet). If I use the server for when I’m out, picking the LAN server when I come home automatically overwrites the outdoor server’s settings with the one it found locally upon opening it. Disabling “Find nearby servers” does NOT fix the problem, as connecting to the LAN will also overwrite the internet server’s settings. Please patch these! Thank you in advance
Well it just happened again, and I think I can explain it more clearly. When I add my Plex server to my Android phone, it saves the server IP and all is well. When I go to my family’s house and add their server IP - expecting to have 2 servers in the list - it instead overwrites mine. Didn’t mean to bump the post so much but this issue is getting really annoying.
Again, apologies about all the bumps. However I just tried the new update, and now not even the ONE IP address I enter manually saves, let alone two. Two different ones merge, and one by itself just disappears.
