Hallo,
seit dem Migraton startet Plex nicht mehr richtig. Installiert ist die Version PlexMediaServer-1.41.3.9276-8f15273fb-x86_64 (ist für Intel CPU und 64bit ja korrekt beim TS-264, richtig ?)
Aber wenn ich dann Plex öffnen will erscheint dieser neue Bildschirm:
Jemand eine Idee ?
Hat immer tadelos funktioniert…
Im Log des Qnap TS-264 8G steht unter:
/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library das hier:
Dec 06, 2024 18:57:36.239 [140239957179192] INFO - Plex Media Server v1.41.3.9276-8f15273fb - QNAP TS-264 x86_64 - build: linux-x86_64 qnap - GMT 01:00
Dec 06, 2024 18:57:36.239 [140239957179192] INFO - Linux version: QTS 5.2.2.2950, language: en-US
Dec 06, 2024 18:57:36.250 [140239957179192] INFO - Processor: 4-core Intel(R) Celeron(R) N5095 @ 2.00GHz
Dec 06, 2024 18:57:36.250 [140239957179192] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Dec 06, 2024 18:57:36.250 [140239957179192] INFO - /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Server
Dec 06, 2024 18:57:36.239 [140239959706256] DEBUG - BPQ: [Idle] -> [Starting]
Dec 06, 2024 18:57:36.239 [140239959706256] DEBUG - MyPlex: mapping state set to 'Unknown'.
Dec 06, 2024 18:57:36.240 [140239959706256] DEBUG - Relay: read 0 cached entries from hosts file
Dec 06, 2024 18:57:36.240 [140239959706256] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Dec 06, 2024 18:57:36.240 [140239959706256] DEBUG - Installing Library Database from ["/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/com.plexapp.plugins.library.db"] to ["/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"]
Dec 06, 2024 18:57:36.275 [140239959706256] DEBUG - MyPlex: no cached data to load for request for https://plex.tv/api/v2/server/users/features
Dec 06, 2024 18:57:36.299 [140239959706256] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Dec 06, 2024 18:57:36.299 [140239959706256] ERROR - HttpServer: Error binding acceptor: Address in use
Dec 06, 2024 18:57:36.299 [140239959706256] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address in use
Dec 06, 2024 18:57:36.299 [140239959706256] DEBUG - Exiting due to bind address already in use
Ich habe auf dem QNAP aus dem Appstore die Version 1.3.0 installiert und die habe mit der Version 1.41.3.9276-8f15273fb-x86_64 ersetzt.
Erst einfach drüber installiert und dann auch nochmal Plex erst deinstalliert und dann direkt die 1.41.3-qpk instaliert. Ohne Erfolg.
Jemand hier eine Idee was das Problem ist ?
