Naming folders of 2 versions of a same title...
I have 2 versions of Battlestar Galactica, the 1978 and the 2003.
Metadata recognized the 2003 folder. The folder’s name is Battlestar Galactica. But for the 1978 version, it doesn’t recognize it as the 1978’s. Instead, I keep getting the Battlestar Galactica: Blood and Chrome. I tried renaming the folder Battlestar Galactica Original and Battlestar Galactica (1978). Same results.
How do I rename the folder?
Also for future reference, how do you name folders with 2 shows that is on at about the same time? Shameless (US) and Shameless (UK) for example.
Hi mustangdmg.
According to thetvdb(I assume that you use the default agent), the old BG should be named "Battlestar Galactica" and the 2003 version should be named "Battlestar Galactica (2003)"
Shameless should be named "Shameless" for the UK version, and the US version should be named "Shameless (US)".
It is always a good idea to do a search on thetvdb.com, for show names, and then copy/paste the title from there to Finder/Explorer (or what you prefer to do your file handling in).
/HuX
