For some reason, when I try to access my Plex Media Server via my phone (Plex residing on the QNAP TS-451+) it shows as offline. When I access it from my PC, it seems to work fine. Thinking this would be a firewall issue, but I can access it fine from my PC. Not sure why my phone would show it as offline; when I am external (outside the house) it shows as offline as well. Any ideas what the issue could be? As a test I setup a second Plex server on m laptop; readily accessible via my phone. Very strange. No firewall or routing that I know of that I set up custom. Lost and not sure what the issue is! Please help
Much appreciated! That looks like what the issue was. Well it was that or doing a “fresh” install of Plex and letting it rebuild the library overnight (likely overkill)
I just moved to a QNAP server a couple months ago and I’ve been having this issue. When testing the remote access, it will come up with a failure, but then I test it again and it works. Hoping it’s just an issue with the version I’m running.
