Need certificate cleared after outage
Server Version#: 1.20.2.3370-b1b651549
Starting Sep 28th, I began getting certificate errors from kaspersky while trying to use plex web. Since then, remote access will not stay on, and my libraries are unreachable through app.plex.tv even while on the same machine the server is running on.
I have the same issue. Everything worked fine up until the 28th, now remote access through all Plex apps is broken. Took a look at the cert and it was issued at 5PM on the 28th of September, I have 0 logged streams after that point.
@ChuckPa Can you clear out a couple more certs?
I suggest that Plex start a pinned thread and post an outage. This seems to be affecting many people looking at the threads in this forum and on Reddit. I just about rebuilt my server before looking at the forum…glad I checked here first…
@Kolby_G
I will post a thread as soon as we get yours resolved. Good idea.
Can you confirm for me you’re seeing 404 in the server logs when PMS tries to update from Plex.tv at startup?
Web logs don’t count .
TO ALL WHO FIND THIS.
If you see “404” errors in your PMS logs as PMS tries to obtain a new certificate from Plex.tv,
Please come to this thread.
Stop the affected server
Give me the name of that server in the above referenced thread.
You may restart it after I reply to confirm.
Interestingly, no. I don’t see 404 specifically. However, disabling “Secure Access” resolves the issue immediately.
I don’t want to leave it like that, but I will until I figure this out.
I just rebooted the server and grabbed the log after a few minutes. Here is every line containing the word “CERT”:
Oct 02, 2020 18:26:00.722 [0x7fe157fb0180] DEBUG - CERT: Installed certificate with fingerprint d0:77:bb:3a:6f:75:74:7e:ea:d8:26:21:45:aa:3b:d9:1a:e1:18:08.
Oct 02, 2020 18:26:00.723 [0x7fe157fb0180] DEBUG - CERT: Installed new private key.
Oct 02, 2020 18:26:00.723 [0x7fe157fb0180] DEBUG - CERT: Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.4df42e245dc944ab9fad0f389c72edcf.plex.direct
Oct 02, 2020 18:26:00.723 [0x7fe157fb0180] DEBUG - CERT: OCSP requests for stapling will be made to 'http://ocsp.digicert.com/'.
Oct 02, 2020 18:26:00.724 [0x7fe157fb0180] DEBUG - CERT: Installed intermediate certificate.
Oct 02, 2020 18:26:00.728 [0x7fe14fcb2700] DEBUG - HTTP requesting GET http://ocsp.digicert.com/MFEwTzBNMEswSTAJBgUrDgMCGgUABBRa0O%2BtN66dcUoU8s4f6J4%2Bqp5hQgQUlIuJ90hyifJRStmIe%2BVhtaqc1QECEA4E6UvvMwzpVm9BWzZfHgM%3D
Oct 02, 2020 18:26:01.330 [0x7fe14fcb2700] DEBUG - HTTP 200 response from GET http://ocsp.digicert.com/MFEwTzBNMEswSTAJBgUrDgMCGgUABBRa0O%2BtN66dcUoU8s4f6J4%2Bqp5hQgQUlIuJ90hyifJRStmIe%2BVhtaqc1QECEA4E6UvvMwzpVm9BWzZfHgM%3D
Oct 02, 2020 18:26:03.734 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:10.588 [0x7fe136fed700] DEBUG - CERT: Certificate will not expire soon.
Oct 02, 2020 18:26:15.592 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.605 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.618 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.631 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.659 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.671 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.683 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.692 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:15.721 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:26:18.017 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:27:15.748 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:27:15.756 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:27:15.765 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:27:15.774 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:27:15.787 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:28:15.805 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:28:15.814 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:28:15.823 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:28:15.832 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:28:15.846 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:29:15.863 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:29:15.873 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:29:15.883 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:29:15.892 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:29:15.906 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:29:25.242 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:30:05.608 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:30:15.998 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:30:16.023 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:30:16.035 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:30:16.045 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:30:16.058 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:31:16.075 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:31:16.084 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:31:16.092 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:31:16.101 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:31:16.114 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:32:16.132 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:32:16.141 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:32:16.149 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:32:16.157 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:32:16.171 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:33:16.188 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:33:16.197 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:33:16.206 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:33:16.214 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:33:16.227 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:33:33.410 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:38.229 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:38.229 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:40.455 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.049 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.066 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.067 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.072 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.080 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.084 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.085 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.240 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.248 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:33:42.260 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:34:16.244 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:34:16.253 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:34:16.261 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:34:16.270 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:34:16.283 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:34:16.625 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:34:16.638 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:34:16.640 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:34:16.645 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Oct 02, 2020 18:34:17.873 [0x7fe14ecb0700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
Oct 02, 2020 18:34:36.629 [0x7fe14f4b1700] DEBUG - CERT: incomplete TLS handshake: tlsv1 alert unknown ca
I can upload the whole log if needed.
Have the remote connections as well started on 28th / 29th Sept. Thanks for the temporary workaround disabling secure connections, not ideal but has stopped the remote access being disabled after every 15sec on enabling it. Hopefully a fix is pending, or a cert refresh.
