N47H4N
March 3, 2023, 4:38pm
1
Server Version#: 1.31.2.6739
Hello guys,
I’ve a problem after upgrading from dsm 6 to dsm 7. I’ve followed the guide here:
Plex Media Server for Synology DSM 7 - Release
This document is to share changes made with DSM 7 and resolve any unforeseen issues before you attempt migrating to DSM 7 for Plex use
YOU ARE URGED TO READ THIS THREAD COMPLETELY BEFORE PROCEEDING OR ASKING QUESTIONS
DO NOT INSTALL Synology BETA software UNLESS INSTRUCTED.
This thread is a LIVING document. Expect it to change.
Synology’s DiskStation Manager (DSM) has undergone significant changes in version 7.0.
Many of those changes affected …
I’ve uploaded the 2 logs folders from Plex and PlexMediaServer.
Help would be very appreciate
N47H4N
March 3, 2023, 6:35pm
3
Sorry, here is my error message:
Not authorized
I don’t see any logs attached to your posts
Please look in the Plex shared folder. Confirm there is no “Library / Application Support / Plex Media Server” shared folder anymore.
If the “Plex” shared folder is empty – migration was successful.
– if not, then we need set permissions (again) on the Plex shared folder and repeat migration to DSM 7
Presuming migration completed ok
– The easiest / quickest way to reclaim ownership of PMS following migration is using the “Plex Claim Token” method shown here
FAQ 31: Reset / Reclaim PMS on DSM 7 (Not Authorized - Locked Out)
Uninstall the app - Use the first radio button (KEEP) option.
[Screenshot from 2022-09-27 16-04-18]
Reinstall the same, or newer, SPK (package) version.
Select the “Install using Plex Claim Token” button
Click the ‘Get Plex Claim Token’ blue hyperlink
In the tab which opens, COPY the token it gives you
[Screenshot from 2022-09-27 16-07-35]
Return to the installation page. You only have 5 minutes. B…
N47H4N
March 3, 2023, 8:26pm
5
Ok so now I’ve my Plex folder empty, only migration.log inside
But now I can’t open it
Please stop Plex in package center.
Using Filestation,
Navigate PlexMediaServer/AppData/Plex Media Server
Right-click “Logs” → Compress to Logs.zip
When finished compressing, Download to your computer
Attach that ZIP file here.
I’ll look at what’s going wrong
