Need some help
Cannot get Plex to work on Xbox one.
I keep getting the same error (no server found server version 0.9.10.3 or higher required)
Hears what I have done to try to make it work
1 my server is up to date
Server is on windows computer
Windows computer is wired, so is my Xbox
On the server it is recognizing the Xbox in the devices tab
Tried restarting the computer and Xbox
Deleted app from Xbox and re installing it.
And still no dice
Any help is appreciated
Thank
Is your server visible when you go to http://plex.tv/web/app? To be able to use the Xbox apps you must have your server setup to be accessible externally, this can also be verified by going to Settings -> Server -> Connect and checking if you have 2 Green check marks.
Here is the support document - [Connect - Plex](https://support.plex.tv/hc/en-us/articles/200289506-Connect), specifically the Connecting Your Server section.
Hi, try to switch plex servers on xbox one - button upper right corner on xbox. I posted resolution on similar issue on another thread.
Double check that you actually have the right version. I believe that for me it showed as "up-to-date" but I had to actually go to the Plex website, login, then download the latest version and install it manually.
