Plex for Xbox One Server not found
When I try to run Plex on my Xbox One I get an error message saying: "No Servers Found, You need at least server version 0.9.10.3 or higher."
Well, I'm running version 0.9.11 on my server (pc) and my other devices (lumia phone and Surface) have no problem connecting.
What's wrong with the Xbox app?
I've tryed uninstalling the app and reinstalling. Doesn't help.
Yes, I have a plex pass, which I bought specifically for my Xbox.
try logging in with the pin #
Hi again,
Problem solved. I went back to my server and found a button "Connect" in the settings. After that I just had to reinstall the xbox app and it found my plex server immediately:-).
Odd that's required for the Xbox, while other devices on the same net don't need it.
Anyway, hope this may be of help to others.
