New App Won’t Show Libraries
my server is 1.42.2.10102
Clients are 10.30.4.4092 and 10.30.4.4093
server is 1.42.1.10060
android app is 2025.25.0
no libraries, tried everything
Thanks, this worked for me.
I had the same problem. Updated my Plex server to version 1.42.1.10060 and my Plex App on my Android to client version 2025.24.0.
Clearing cache shows my library again.
Same issue. Outside of my home network, the iOS app won’t show the libraries at all.
Server and App both up to date and I’ve tried all the suggestions listed so far and nothing works.
This happens on and off for me, was working fine a few weeks ago and now won’t show my media server as online.
I can access it fine from the browser on my iPhone just not the app.
By the looks of things, I may have to try rolling back the app and see if that fixes it.
Having this issue on my android phone app. Web app is fine, android tv plex app is fine, just the android app on my phone is affected.
By the sounds of it, Plex has done nothing to solve this. Of course after I got my lifetime subscription there is a new dealbreaking issue that seems to be persistent as well.
I can see the libraries in my “Favourite Libraries” but with the error “This library can not be found.” As I said, no problem at all using the libraries on my other devices.
Very frustrating and as a paying customer I would expect better.
There’s also bugs on all apple clients as well, which plex seems to be never fix in that stupid „experience“…
On all my devices I have to setup every single time after starting the App, that I have to first time setup which libraries are favorites.
Then watch a movie and tomorrow I have to re-setup again and again if I wanna have a Homescreen and watch a movie from my plex server. Kind of useless like this and started to use Infuse instead of plex app…
Yeah it is terrible. And no support from Plex available even though I am a lifetime member. And ppl have had this issue for 5 months.
I’m having the same problems and seems like it started with the new app. Everything works except my phone, including Nvidia shield, web, phone says can’t access library. If I hold on the libraries tab button it shows a list with all triangles next to them and they dont work either, yet all my media is visible on the recently added sections etc and they play just fine. Very frustrating. I’ve tried all the suggestions, uninstalled, reinstalled the phone app and so on. I just have avoided using it on my phone since it never works for me. Any updates on this?
Having the same issue, iOS latest, macOS latest, Plex server latest on Dec 21 2025
I did some changes below, not sure which bring back the library in my iPhone app, but hopefully it helps, especially Step 5
  1. Set DNS to other than ISP DNS (mine is Adguard filtering). I don’t think this this fixed the issue, but since I performed this among other things so I should include here.
  2. Set Client IP version to IPv4 only. Again, I don’t think this is the solution.
  3. In the Plex Network settings: (still think this is not the solution)
    1. My Mac as Plex server is using both LAN & Wifi, I choose Preferred network interface is my LAN NIC
    2. Turn off Webhooks
  4. Authorized Devices: I delete the oldest authorized device
  5. Plex Home: (I think this is the solution)
    1. I creata a Managed account to test, set a pin. In this Test account, I was able to see my full library like the issue has never happened. Then I switch back to Home Admin, and voila the library shows up. Then I proceed to delete the test acc, and the library is still there for me in Admin acc.
If this can help bring back your library, please let me know. :waving_hand:
Excuse my English, I’m still learning.
So I lost my libraries from my Android App,.. Having just migrated my collections to a single server RAID storage,.. and hosting on a ‘TrueNAS’ installation… I assumed all my troubles were over….
Then discovered my music library had gone from my phone but existed on my PC installs..
having read this article,.. and found PlexAmp,. I now have my music libraries back,..
Now sorry to moan,… ONE unified location and App for my media was why opped for Plex,.. splitting the Apps,.. was not what I wanted,.. this is a backwards step IMHO…
I hope this ‘splitting’ can be fixed in the future… ( moan Over ). Thankyou
Thank you so much. Your 5th listed solution–as simple as it sounds–did fix the issue. However, in my case, after starting the Test account, i COULD NOT see any of my libraries when signed into that account. But the creation of the Test account still somehow allowed my pre-existing accounts to access libraries again. Completely bizarre. But anyone having this issue in 2026 may want to try this.
