Server Version#:
Hi, i’m running pms in windows (last version)
this machine Beelink SEi8 Mini PC con Intel 8th Gen i5-8259U Processor (Turbo 3.8Ghz), 8G DDR4 + SSD NVMe M.2 da 256 GB, WiFi 6, 1000Mbps, Intel Iris Plus Graphics 655, Doppio HDMI, Tipo-C, BT 5.0, Windows 10: Amazon.it: Informatica
i’ve added my whole file(34120 episodes of anime)
it’s running 2 day now and it yet have to finish… how long it will take?
anyone can give me an idea?
it’s matching with agent hamatv
The scanning or metadata gathering is taking time?
If your series are not directly in the library root well will scan them at every scan, otherwise only when the folder content changed so it’s fast the second time
It will take 10 second per series due to AniDB ban protection… You have 12TB of anime if 300MB a pop… That is the biggest I have ever seen…
If it completes and does not ban you and 90% series were
With thetvdb agent I had already finished? My series are structured as main folder(entry in plex\ anime series\episodes
I have 1372 series totally
After 2 day it hasn’t finished and library is still unavailable
Any guess for the ETA?
So your scannner did complete its scan, but the agent metadata update takes time?
If so the library should be available…
You need to check the HAMA agent logs, HAMA custom series logs in agent data folder for a completed series, something times out definitely. You are using last version of HAMA i hope otherwise MAL times out and take 2 min per series…
