Unfortunaly, changing player does not solve it for me⦠That very much sound like a RAM problem (file is a high bitrate H265 encode). Guess I should have bought the Shield Proā¦
The 7.29 update appears to have broken the old playerās ability to play 4K HDR HEVC. It stutters and crashes now, causing my Shield remote to not function for a short while. The new player however can play it just fine, but I still prefer the old player due to it displaying playback information in the top left - if the new player did this I would use it all the time.
Also, no matter which player I use now when playing 4K HDR HEVC, pressing the settings button is a death sentence. Completely freezes the Shield. All I want to do is see what refresh rate the video is playing at. Is that too much to ask?
Same behaviour here. Even opening the shield menu settings tend to crash Plex most of the timeā¦
The main menu settings, the one that open by default when pressing the top right button on the shield remote.
But anything I try to do when Plex is playing the file is either very slow or crashes the Plex app entirely. It seems to happens only with 4K high bitrate (>20ā000 kbps average) files.
I can also confirm that Plex on my Shield Tube now seems okay with 4K HDR HEVC files, but only if their bitrate is around 10Mb/s. Any higher than that and it stutters with the old player and flatout crashes with the new player. I watched two 4K HDR HEVC movies recently (10.8Mb/s & 10.4Mb/s) and they played fine. Just finished watching another that was 17.8Mb/s and had to use Plex For Kodi instead - that played it without any issues.
I donāt know what it is about Kodi, but it handles 4K a lot better than Plex does.
I would also like to weigh in. After having frustrations that my Roku Ultra was choking on high-bandwidth UHD videos due to the non-gigabit Ethernet port on it I finally bit the bullet and bought a Shield TV (tube) even though I like the Roku ecosystem.
Load up the same file that made me buy the Shield in the first place and it stutters a bit and then crashes Plex. Not a great first impression. Like others, if I play the exact same file directly via VLC app it works perfectly so it definitely appears to be an issue with Plex specifically. I am running 7.31 and the latest Shield firmware.
As a workaround, I am now using the Plex for Kodi addon. Although it is not perfect (I sometimes have to relaunch the file or even restart the shield so the video isnāt lagging), it works way better than with the standard Plex app.
