@chrisallen, unfortunately, I restarted Plex and reverted to an old DB, so a lot of my logs were lost (don’t have Plex Scanner, Plex Scan Matcher, etc. from that time). The only one that remains is the Plex Media Server.log. To clarify, here are the steps I took.
- I had already upgraded my library and refreshed metadata a few days back when the agent was released. All my items seemed to be matched properly and had correct custom metadata (with the exception of collection summaries which were all deleted and cannot be edited)
- I decided to name my movies as per the convention you mentioned. I turned off the Empty Trash after scan option, shut off Plex, and ran a mass rename using Radarr.
- I restarted Plex, and forced a scan of my movie library.
I can definitely see it working on the mass rename, but the log is only filled with items like the below. I don’t see any other types of lines, just this for 2000 movies. In Plex, the alerts UI (which is not logged anywhere AFAIK) seemed to indicate that the item was first deleted, then a new item was created and metadata loaded for that. I stopped the scan in middle when I realized what was happening, but it was still running 40 minutes after I started it.
Jul 26, 2020 22:38:08.647 [41480] INFO - Part rename detected [G:\Movies\The Photograph (2020)\The Photograph (2020) [tt7798646] [8bit] [AVC] [DTS-HD MA 7.1].mkv] was renamed [G:\Movies\The Photograph (2020)\The Photograph (2020) {imdb-tt7798646} [8bit] [AVC] [DTS-HD MA 7.1].mkv]
Jul 26, 2020 22:38:08.834 [34868] ERROR - Unknown metadata type: folder
I don’t have .nfos, only the movie files. I tried copying those files to a new directory and creating a test library with the new naming scheme. They matched incorrectly to the movies I listed before.
For specifics, here is the full movie name and which movie it matched to. The matched movie is not even on IMDb (as far as I can see), so no clue what’s happening here
G:\Test\The Photograph (2020)\The Photograph (2020) {imdb-tt7798646} [8bit] [AVC] [DTS-HD MA 7.1].mkv
EDIT: It is worth noting that even with the old agent, whenever I swapped files out or did renaming, the Plex scanner seemed to always do a delete + create rather than just updating the existing item. It only did that with movies, not TV shows where the items were updated in place. This often led to annoying behavior like switching back posters, though as noted, other locked fields remained static. This behavior seems to not have been changed with the new scanner/agent (unfortunately), the only thing changed seems to be matching accuracy for some movies.
