New Plex Scanner and Collections
I ran through the steps to switch to the new scanner. I set my collections to Minimum automatic collection size: 2. My understanding is collections will only appear with 2 or more correct?
If so, after refreshing all my metadata I ended up with more, not less. I see a bunch with 1 movie in them. Did I mess something up?
Are those collections you had created before?
From a sibling thread:
thank you for the info. I can definitely wipe all my collection data, that said one is definitely new as I added the movie the same day i updated the library.
So would the course of action be do:
  1. select all collections, delete
  2. select all movies
  3. edit collection tab to unlocked
  4. re-run meta scan?
refresh metadata. not scan (unless you need it to look for new files).
Plex
thats what i meant, my bad. That said, I have no way to select all movies and unlock the collection. thoughts? i figured out i needed to hide collections to select all, however they dont seem to take unlock/lock changes when the field is blank.
