New update broke playlists on Fire Stick?
Server Version#: v.1.19.3.2764
Player Version#: v.8.0.1.17410
Is anyone else having trouble with playlists not working properly after the latest Plex app update on Fire Stick?
I’ve had playlists set up that I use daily with no issues until this last update (v.8.0.1.17410). When I put on the playlist the episode will play like normal and then after it ends the screen will go black and the episode timer will count down again from the start with no audio or video. If I let it finish running through again like that it will then move on to the next episode and at the end of that do the whole thing over again so it goes like episode>black silence for the full duration of the last episode>next episode>rinse and repeat.
It does this with every playlist I had prior to this issue and every playlist I have made since. I have rebooted the router, rebooted the server, made sure my server is up to date (v.1.19.3.2764), force stopped and cleared cache and data on the app on the Fire Stick, uninstalled and reinstalled the app on the Fire Stick, deleted the old playlists and completely remade them, made completely different playlists, marked all episodes in the playlist as played, switched from the new video player back to the classic video player.
At this point I’m out of ideas and hoping someone out there might have some suggestions.
Just wanted to give this a bump. I am experiencing the same problem. In addition, it sometimes skips an episode or just “hangs” and I have to press play.
I’m facing exactly the same annoying issue, not only with playlists but also with episodes in a TV show (mostly kids shows because episodes are short).
I’ve opened the issue on this forum sometimes ago. Looks like Plex team doesn’t even test the new versions before releasing it.
What I noticed that the same video plays back right after it plays for the first time but this time with no video and audio.
I tried to play around with every possible settings but no luck.
Also I have to mention that I have Plex for Kodi on the same Fire Stick device and it plays back the same Playlist flawlessly.
It’s so frustrating…
Hoping that our complains are noticed by Plex’s support team.
Cheers
