My LG 695v can not play the main movie after the ver 1.4.1.3362 update. I dont know if it is me or my firmvare in my TV. Does anyone know?
Ps I try install ver 1.3.4.3285 on a nother pc and it works fine on my TV.
Same issue, problem started with 1.4 versions. Movie begins then skips thru to end
Same issue here… started with version 1.4.
Can I easily downgrade or will it break the database?
Versions
Server
- PMS
1.4.1.3362 - on
Ubuntu 14:04 - in a
Docker container
Client
- LG smart TV:
55LA9659-ZA - Software Version:
04.28.15 - SDK Version:
03.05 - Plex Client Version:
2.12.10(downloaded from the LG store)
Description
Streaming is no longer working properly on an LG TV after I’ve updated the Plex Server.
Steps to reproduce
Upgrade PMS to 1.4.1.3362 and try to play several TV show episodes on a LG smart TV.
I’m using my own Docker Image called dbarton/plex:1.4.1.3362.
Actual behaviour
The TV show starts and after a couple of seconds it stops.
The timeline shows only a couple of seconds (e.g. duration of 2 seconds) instead of the real media length (e.g. 55mins).
Expected behaviour
It plays w/o any issues of course ![]()
Troubleshooting
I downgraded PMS back to 1.3.4.3285 to see if it’s really the new version.
Apparently it is!
Workaround
Downgrade PMS to 1.3.4.3285 until problem is fixed.
Additional infos
Feedback to developer (on LG TV) was submitted a couple of minutes ago!
