I have installed McAfee on my devices, with the VPN on I can’t use the Plex app to playback on my tv, with the VPN off no problem.
Any suggestions workarounds so I can leave the VPN on and still use Plex?
Using a VPN isolates your PC from other devices on the network.
See if the VPN supports split-tunneling, which allows applications to bypass the VPN.
If so, enable it for Plex.
