My VPN does not offer SPLIT TUNNELING on Macs. yet … yes, I may have to switch VPN’s but for now, is there anyway to get around the SEFVER is on a “relayed connection .”
The playback is pretty flakey and mostly unwatchable.
Any suggestions? Thanks.
(yes, I can turn off the VPN but my company prefers it stay on for files and access so yes, I can log off to watch PLEX but it’s a hassle as it’d be nice to have access to my library. Thanks!)
Are you getting a relay connection when you watch Plex inside your network?
Yes, I am on WiFi. When I turn off my VPN, the server connection is “DIRECT.” Can’t remember if it says anything or there’s no “RELAYED CONNECTION” shown. Everything on PLEX works great (with VPN off). Thanks and any help. THX!
What VPN are you using?
You should have a way to allow LAN traffic on your network without being affected by the VPN
Not sure if this is of any help but I suppose split tunneling is problematic depending on which Mac OS you’re on, specifically newer OS’s.
Yea, they have a tunneling option but it’s not available for Macs
… I was just hoping there was another workaround but I’ll check out the link and see if that’s workable, thanks!
