No complet metadata in Library
Server Version#: FreeNAS-11.3-U1
Player Version#: 1.18.9.2578
Hello,
i describe this problem.
Plex server run correctly, donwload all poster for movies/Tv’s show
But nothing appear automatly :
If use manual edit with the pencil i found :
The descriptions and others info is blank :
I tried :
Basic version on FreeNas (1.18.2.2058) and similar problem.
Updated with this tuto https://www.virtualmvp.com/update-plex-freenas-11-3/
Agent and Library configured on French before create.
With this tuto in french section : [Tuto] Configurer ses bibliothèques Plex en français
Fresh Install
If you have an idea, i’m no find solution (or no have good search terms).
Thank you
Plex Media Server Logs_2020-03-29_18-32-49.zip (4.8 MB)
I found !
The folder in jail, to which mountpoint pointed not have correctly right.
Is root right and no plex.
Use chown -R plex:plex in folder and it’s OK.
