ALB1
January 31, 2021, 1:17am
1
Hey folks, super excited about Plex Arcade but having a challenge. hoping to get a little direction on this one:
Updated Plex to Version 1.21.2.3943
Paid for Arcade subscription.
Connected a Parsec account.
Confirmed it’s connected.
Added a Games library. Have tried this both with and without selecting a folder.
Made sure the checkbox to add default games was checked.
Nothing in the games library. Have done this at least 4 times, with reboots and such in between.
Appreciate any help!
Cheers,
Al
elan
January 31, 2021, 4:33am
2
so sorry you’re having trouble! i suspect you’re running into one of the issues which will be fixed in the next release, but for now you can download the games from https://files.plexapp.com/gaming/roms/Games.zip and unzip them wherever you want to point the library to.
ALB1
January 31, 2021, 11:06pm
3
Thanks @elan , that fixed it. I see the games. Having issues getting some to play, but some work. Assume that’s a beta thing.
Addionally, I’m unable to add my own ROMs and have them show up.
I’ve created a new folder for them and added it to the library.
I’ve set up directories “Arcade” and “Atari 2600” (named just like Plex does).
I’ve set up a folder for the game itself inside those directories.
I’ve added the ROM inside that folder (same name as the folder).
Of course, refreshed the libraries a couple times.
I think I’ve done everything in this link, but they’re not showing up. Naming and organizing Game files and Cores | Plex Support
BTW, these two test ROMs I’ve added work fine on my Raspberry Pi Recalbox.
Cheers!
Al
