No login screen, No Sign UP
Unable to log in or create an account since yesterday, on the home screen, I wanted to point this out. Thanks
Same problem here. I’m unable to log in to app.plex.tv. I cannot log in 3rd party apps which use plex to connect.
Which type of web browser do you use?
Do you have some browser add-ins which apply filtering or blocking?
Do you use a VPN?
I’ve attempted to access it using Vivaldi, Safari, and Chrome on macOS across two devices, and also tried Chrome and Vivaldi on Android.
I’ve even disabled uBlock, but nothing has changed.
I’m not using a VPN.
I use Chrome, I even tested with Edge, Ublock is deactivated and I don’t use a VPN, I even tested in private browsing, same result…
This is the screen where I am stuck :
Developers are on the case. Stand by, please.
Related [BUG] Can't connect to Plex to authorise a third part app to connect
Stuck at this screen too, thanks for the update
https://status.plex.tv/
I am told this should be solved by now.
Please report back if you’re still having trouble.
https://status.plex.tv/incidents/fvmw7mhr71vd
I can connect, but then it will automaticly disconnect after few seconds.
I tried it with Soundiiz and it is still not possible to use Plex
Here are the logs if it can help :
Plex Media Server Logs_2024-03-12_21-42-34.zip (3.4 MB)
Hi, same here ! I can’t connect. It’s seems resolved at the end of last week, but since yesterday it’s down again
@Tangs
From what I can tell, you have a server running on IP Net 192.168.0.0 with a WAN address as 192.168.1.1
So looks like you maybe have a double NAT setup?
Hi, I’m still having trouble when try to sign in with plex account on tautulli or other third party app
