What I have been looking at were 401’s and not 404’s. I would like to see your logs to see what similarities there are. I have tried the requests myself and I did not get 401s. If it is the same as the others, will then explore what cloudflare is returning on some specific requests
The common factor so far is that the 4 sets of logs I looked at with this issue are all for servers located in Florida - hence my thoughts that there may be a regional Cloudflare issue
From reading this thread, they look very alike to my issue, since this got more responses, maybe merge my issue into this, or just close my thread. I’ll keep myself looking at this for responses on fix. After Update, No Movie metada
You have a DNS lookup problem. The DNS lookup IP your machine is pointing too isn’t correct somehow or the machine itself isn’t seeing the internet.
Mar 26, 2020 21:34:08.460 [0x7f9c77d00700] ERROR - Error issuing curl_easy_perform(handle): 6
Mar 26, 2020 21:34:08.460 [0x7f9c77d00700] WARN - HTTP error requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1 (0, No error) (Could not resolve host: plex.tv)
Mar 26, 2020 21:34:08.460 [0x7f9c77d00700] DEBUG - MyPlex: no cached data to load for request for https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
Mar 26, 2020 21:34:08.460 [0x7f9c77d00700] ERROR - MyPlex: Error -6 requesting XML from: https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
Mar 26, 2020 21:34:08.460 [0x7f9c77d00700] ERROR - MyPlex: Couldn't get list of access tokens from myPlex.
Mar 26, 2020 21:34:08.464 [0x7f9c3b7fe700] DEBUG - Request: [127.0.0.1:51186 (Loopback)] GET /channels/all (6 live) GZIP Token ()
Mar 26, 2020 21:34:08.464 [0x7f9c517fa700] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Mar 26, 2020 21:34:08.464 [0x7f9c517fa700] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
Mar 26, 2020 21:34:08.465 [0x7f9c76cfe700] DEBUG - Completed: [127.0.0.1:51186] 200 GET /channels/all (6 live) GZIP 0ms 387 bytes
Mar 26, 2020 21:34:08.469 [0x7f9c517fa700] ERROR - Error issuing curl_easy_perform(handle): 6
Mar 26, 2020 21:34:08.469 [0x7f9c517fa700] WARN - HTTP error requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1 (0, No error) (Could not resolve host: plex.tv)
Mar 26, 2020 21:34:08.469 [0x7f9c517fa700] DEBUG - MyPlex: no cached data to load for request for https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
Mar 26, 2020 21:34:08.469 [0x7f9c517fa700] ERROR - MyPlex: Error -6 requesting XML from: https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
Mar 26, 2020 21:34:08.469 [0x7f9c517fa700] ERROR - MyPlex: Couldn't get list of access
I was asking in case there is a botched update and I need to roll back to an older version to get a working version. Not sure why Plex wouldn’t make older versions available?
