Server Version#: 4.4.1.1146 (TS-453A) / PlexMediaServer-1.18.4.2171
So I made a post a few months back, but it was closed automatically.
I had the same issue back then, but when I downgraded to 4.3.6 + 1.17 my issue went away.
Because Plex will require at least 1.18 going forward in order for artwork to properly work, I am forced to re-visit my issue, and try to resolve it.
I was able to upgrade to 4.4.1.1146 and while on 1.17 everything works as intended. But every time I upgrade to 1.18, remote access stops working.
Now here is where it’s strange: I am still able to play my media, using PlexKodiConnect, but every official app/web app won’t access the server. If I downgrade to 1.17 it works again.
@dane22 was helping me prior, and I have the plex library share app installed still. However, the folder is huge now, so I wonder if I can clear it and run it again?
You are picking up 4 months of changes with a big one concerning music. Depending on how many files you have that little processor is going to be busy for a while. Monitor the Plex Media Server.log and be sure that no SQLITE error messages are there or corruption.
Yes. With it being a NAS I suppose you could try to Optimize first and see if it will upgrade before going through the effort of copying the file off to a pc and doing the repair.
I must say this is where it starts being a bit over my level of expertise. Does the optimization require me to SSH or is there some built in app or function I can use?
Firstly, thanks for taking your time trying to help me
As for your questions, yes I upgraded to 4.4.1 as soon as the first public release came, then downgraded to 4.3.6 and now upgraded to 4.4.1 again. I have always updated to the latest version of Plex as well as soon as it came out, though not quite sure if I updated QNAP or Plex first that time.
Sadly the server is not responding. I could downgrade to 1.17 to do the optimization, but is this equivalent to the Linux SSH repair?
