No Servers Found
Merry Christmas (Sarcasm Intended)
I definitely just paid for your mobile app, your subscription, and now i can't even access this on my box (which was the whole reason I paid money for this.)
This is pissing me off nice and good, and I really hope I get an answer, stat.
"No Servers Found"
Server version 0.9.10.3 or higher required.
Definitely downloaded everything that is most recent and I'm being absolutely jacked by you guys.
Can't get on my xbox one with your app that I have paid money for.
This is a joke and you seemed trustworthy.
You may want to address this issue immediately.
Stop winging plex is a great app.
But i am also having the same issue, works fine on everything else but getting no servers found error
Same here.  Not a happy camper.
https://forums.plex.tv/topic/134179-xbox-one-no-servers-found-dammit/
Same here!
As per my comment on the other post download the latest update from https://plex.tv/downloads for your server you will get the latest version.
I think the feature is that new the third parties maybe still testing only my opinion.
But this is the best app I can find used to use Mymovies but a bit clunky this is nice.
working on it.....
Ok I fixed the issue.  Here's what I did tonight and my Xbox One is now connected, finally!
On my computer (where my media server is):
- Ensured I had the most up-to-date version of the Plex server on my computer.  In this case it is 9.11.7
- Signed into Plex on my computer.  Launched the server (LAUNCH top right).
- Went to Settings->server->show advanced.  At the bottom there is a box for "Update Channel" and I selected "Plex Pass" instead of "stable".
- Ensured my library was showing up on my computer.  All is good.
On the Xbox One:
- From being on, I held down the power button until it turned off. (Hard power down).
- Reset my router (unplugged it, waited for a few seconds, re-plugged it in, let it power up and connect.  Re-connected my computer).  This is a step I found in another thread, and I think it made the difference).
- Turned on my Xbox One.  Went to the Plex app and it finally recognized my computer.... FINALLYYYYY
Hope this is helpful to others!!
The other solution is to click the retry for scanning for a plex server. Then arrow over to the server box in the top right corner and select your Server.
