Everything works except there aren't any thumbnails.
Any ideas?
Cheers,
Edit: I'm using unblock-us as well
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3 ios 5.3
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 173.212.85.246
The device and operating system (including version number) that PlexConnect is installed on: iMac - Mountain Lion 10.8.4
The local IP address of the device that PlexConnect is installed on: 173.212.85.246
The device and operating system (including version number) that the Plex media server (PMS) is installed on: iMac - Mountain Lion 10.8.4
The Plex media server (PMS) version number you are running (**do not put 'latest'**): 0.9.7.28
The local IP address of the device that the Plex media server (PMS) is installed on: 173.212.85.246
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. I'm using the BAA PlexConnect.app
f00b4r... as long as enable_plexgdm is True, the ip_pms doesn't really matter - well, there even is no good reason to change it :-). PlexConnect will connect to the address returned by PlexGDM, nothing else.
In the beginning ip_pms was also used as a fallback in case of a negative GDM outcome. But I think, this is long gone...
