ATV model: ATV 2, Firmware 5.2 (6010.96), Model MC572FD/A TV resolution 720p HD- 60 Hz
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.101
The local IP address of the device that PlexConnect is installed on: 192.168.1.101
The device and operating system (including version number) that PlexConnect is installed on: Mac Mini, MacOS Sierra 10.12 (16A323)
The device and operating system (including version number) that the Plex media server (PMS) is installed on: As above Mac Mini
The Plex media server (PMS) version number you are running (do not put ‘latest’): Version 1.1.4.2757
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.101
The PlexConnect version number. Using OpenFlex: 0.5-dev-110616
The contents of your ‘Settings.cfg’ file (this is created at first clean shutdown of PlexConnect, using CTR+c):
[PlexConnect]
enable_plexgdm = False
ip_pms = 192.168.1.101
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = Normal
logpath = .
PlexConnect.log
01:06:18 PlexConnect: started: 01:06:18
01:06:18 PlexConnect: Version: 0.5-dev-110616
01:06:18 PlexConnect: Python: 2.7.12 (v2.7.12:d33e0cf91556, Jun 26 2016, 12:10:39)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
01:06:18 PlexConnect: Host OS: darwin
01:06:18 PlexConnect: PILBackgrounds: Is PIL installed? True
01:06:18 PlexConnect: IP_self: 192.168.1.101
01:06:18 DNSServer: started: 01:06:18
01:06:18 DNSServer: ***
01:06:18 DNSServer: DNSServer: Serving DNS on 192.168.1.101 port 53.
01:06:19 WebServer: started: 01:06:19
01:06:19 WebServer: ***
01:06:19 WebServer: WebServer: Serving HTTP on 192.168.1.101 port 80.
01:06:19 WebServer: WebServer: Serving HTTPS on 192.168.1.101 port 443.
Issue: Have tried both installations from GitHub and also now with OpenPlex, my ATV2 connects and finds PMS, loads up TV Shows etc. but i get no thumbnails, fanart, metadata etc. info and when i try to play any file i get the error message ‘An error occurred loading this content’…
Have tried and you see to change settings to point to the right PMS ip but still no joy…any ideas, what am i doing wrong here?
Thanx in advance!!
