Not detecting imdb und tmdb-id
Server Version#: 1.22
hello plex guys,
i am having trouble detecting one of my movies correctly: “The captains close up”. I added {tmdb-} and on another try {imdb-} number but still plex wasnt able to detect it correctly.
My guess: tmdb and imdb stores this as a mini series. But my version is a one file version from the blu ray. Is this the reason, because it doesnt work? With various other movies i do not have this kind of trouble.
Kind regards
This is to be placed as a TV Series.
I created 5 dummy episodes for the scanner to grab (no special naming)
[chuck@lizum ~.251]$ ls -la /vie/qa/tv/The\ Captains\ Close\ Up/
total 52
drwxr-xr-x.   3 chuck chuck  4096 Mar 14 12:01 ./
drwxr-xr-x. 948 chuck chuck 45056 Mar 14 12:01 ../
drwxr-xr-x.   2 chuck chuck  4096 Mar 14 12:01 Season 01/
[chuck@lizum ~.252]$ ls -la /vie/qa/tv/The\ Captains\ Close\ Up/*1
total 28
drwxr-xr-x. 2 chuck chuck 4096 Mar 14 12:01 ./
drwxr-xr-x. 3 chuck chuck 4096 Mar 14 12:01 ../
-rw-r--r--. 1 chuck chuck  290 Mar 14 12:01 The Captains Close Up - S01E01.mkv
-rw-r--r--. 1 chuck chuck  290 Mar 14 12:01 The Captains Close Up - S01E02.mkv
-rw-r--r--. 1 chuck chuck  290 Mar 14 12:01 The Captains Close Up - S01E03.mkv
-rw-r--r--. 1 chuck chuck  290 Mar 14 12:01 The Captains Close Up - S01E04.mkv
-rw-r--r--. 1 chuck chuck  290 Mar 14 12:01 The Captains Close Up - S01E05.mkv
[chuck@lizum ~.253]$
It matched normally – as a TV Show (“For TV” specials / mini-series are done this way)
Hi ChuckPa,
first: live long and prosper :wink:
Great documentary, bit to much Shatner, but great.
I am not sure if i understand what you’re saying.
Of course i could create five dummy files. But it wouldnt solve my issue. I’d like to watch my movie with plex. With dummy files … well … i could watch dummy files.
So, wild guess: the first of the files is the movie and the other four are dummies? Or did i miss something?
Thank you very much for your instant help. Your support is always appreciated.
Kind regards.
I created 5 dummy files to verify the scanner is working correctly.
  1. I went to IMDB and got the correct name.
    The Captains Close Up (TV Mini-Series 2013) - IMDb
  2. Seeing that it’s a “TV mini-series” (emphasis on “series”), I created it in Plex as if it were a normal multi-season show. This “Show” happens to have only 1 season with 5 episodes.
The point I’m making is:
  1. This is a TV program. I hope you’re placing it in a TV Shows library type?
  2. Naming it as it’s named on IMDB, as a TV show, the scanner finds everything without any special “force” of the ID.
  3. If you’re placing this in a Movie section, then it will give you issues.
  4. What do your names look like? Are they proper TV Series naming ?
I went ahead and grabbed those episodes.
[chuck@lizum ~.249]$ cd /vie/tv/*Captains*
[chuck@lizum The Captains Close Up.250]$ pwd
/vie/tv/The Captains Close Up
[chuck@lizum The Captains Close Up.251]$ ls -la Season\ 01/
total 13553464
drwxr-xr-x. 2 chuck chuck       4096 Mar 14 12:47 ./
drwxr-xr-x. 3 chuck chuck       4096 Mar 14 12:44 ../
-rw-r--r--. 1 chuck chuck 2806696793 Mar 14 12:45 The Captains Close Up - S01E01 - William Shatner.mkv
-rw-r--r--. 1 chuck chuck 2915623869 Mar 14 12:46 The Captains Close Up - S01E02 - Patrick Stewart.mkv
-rw-r--r--. 1 chuck chuck 2453544722 Mar 14 12:45 The Captains Close Up - S01E03 - Avery Brooks.mkv
-rw-r--r--. 1 chuck chuck 2786164051 Mar 14 12:47 The Captains Close Up - S01E04 - Kate Mulgrew.mkv
-rw-r--r--. 1 chuck chuck 2916681573 Mar 14 12:46 The Captains Close Up - S01E05 - Scott Bakula.mkv
[chuck@lizum The Captains Close Up.252]$
With no assist whatsoever, in a TV series library,
This is something I can watch :wink:
Hello Chuck,
sorry i didnt make myself clear. I did get it: actually its a tv series. BUT, i only have one file which includes all episodes as one file. This is the way the bluray was delivered.
So, what i do not understand: i have one “movie” file. How would it solve my issue creating dummy files? The dummy files would be detected as the real episodes. But, as they are dummies, i would not be able to play them.
I hope, i made myself clear.
Kind regards
Thank you for clarifying.
That makes a whole lot of difference.
There is a How-To to break out that single file into its individual episodes.
Thank you ChuckPa. I’ll look into it.
TV Show Library/
....The Captains Close Up/
.......Season 01
........The Captains Close Up - S01E01-E05.mkv
TV Show, of course, but without further ado Plex will grab all the individual descriptions and list them to Appear as 5 episodes - but there will only be one when the Play button is pressed and it will play in it’s entirety.
great idea, thank you
