Not showing movie poster by default
Server Version#: 1.25.3.5409
So some movies are not showing posters.
Both of these are recently added.
One shows fine, the other does not (Meta data is there)
In the fix match I can see the poster,
But is not applied.
Its not just this movie its a 6 or so across the library.
I’m looking at the logs, but the only thing I can find relates to that thumbnail in the matcher logs.
Jan 27, 2022 12:29:39.745 [1356] DEBUG - MediaFile: found embedded image, saved to XXXXX
Anywhere else I should look?
BTW,
Agent settings for the library
Ok,
So this is interesting.
Looking at the meta data, its actually seems to be defaulting to the thumbnail for some media.
Any idea why?
Are they mp4 files? possibly that thumb is embedded in file and is using that. if so try editing library and disabling Prefer local metadata then refresh metadata for movie
That makes sense, but it wasnt selected :frowning:
Can you try deselecting use local assets as well.
OK, taken that off as well.
I also fixed the remaining posters manually, so, might not see the results for a while.
But thanks for the help :slight_smile:
