I’d be happy to do that. It seems like it’s almost on every HD channel. How do I go about doing that? I know how to send Plex logs but not sure how to send a raw capture from the hdhomerun tuner.
Getting samples for DVR issues
Restart your server, and allow the EPG to load
Start a direct .ts sample from the tuner. You can do this by using a command such as:
curl http://tunerip:port/auto/channel > /users/outputpath/plexSamples/samplefile.ts
(You can copy the tuner URL bit from your logs, if it helps. You can find this by filtering on final URL) -
Start a recording in PMS of a problematic channel
Cancel the recording after a minute or so
Stop the direct capture from the tuner
Download the complete logs from the server
Zip up the logs, the direct sample from the tuner, and the recording from PMS, and post them here (tag me to make sure I see them)
