I have an Nvidia Shield Pro passing audio and video through a Nakamichi Shockwafe 7.1 Pro - the Shield/Soundbar plays everything I throw at it and I love it but I wondered if there was a way (profile/etc) I could enable the Shield to default to the 4k video file and 7.1/Atmos/DTS-HD audio track rather than manually selecting them prior to playing the file.
I’ve noticed the Apple TV 4K defaults to 4K files - press play and it’s 4K. I have tried using the enhanced/normal player on the Shield and this does not seem to impact the file chosen by default. Automatically adjust quality does not appear to impact the situation either. Currently home and remote streaming are set to Maximum for audio and video. I have everything hardwired on a One Gbps connection.
Has anyone found a work around for this issue that is not creating a separate library for 4K? I know I can choose the file from More>Play Version, but given everything in this client setup is compatible for 4K and various surround codecs, should it not automatically default to the 4K file?
