Nvidia Shield TV will not play any media
Server Version#: 4.57.2
Player Version#: 8.17.1.25326
When playing on my Shield TV i can not play any content but will play on all other devices.
May 19, 2021 21:01:47.775 [13871] Error — XML: Entity: line 1:
May 19, 2021 21:01:47.775 [13871] Error — XML: parser
May 19, 2021 21:01:47.775 [13871] Error — XML: error :
May 19, 2021 21:01:47.775 [13871] Error — XML: Start tag expected, ‘<’ not found
May 19, 2021 21:01:47.775 [13871] Error — XML: status=ok
May 19, 2021 21:01:47.775 [13871] Error — XML: ^
May 19, 2021 21:01:47.775 [13871] Error — Error parsing content.
May 19, 2021 21:01:47.776 [13871] Error — Error parsing XML: Error parsing file.
May 19, 2021 21:01:47.776 [13871] Error — SSDP: Error parsing device schema for http://192.168.50.178:9080
Same issue. Started yesterday for me. Before then, all was perfect. Anyone know of a fix maybe? :frowning:
I have tried clearing cache and data, rebooting the device many times, etc.
I’m having the same issue for around the same time frame, were either of you able to fix it? Can anyone help look at the debug log?
Any plex staff here? my other android TV is now having the same issue, did something change?
See the post linked below. Check for the certificate error in Android TV logs to see if it applies to your setup.
Android, Android TV, Fire TV, Portal Logs
