Played with Sneakypie’s fix last night. My symptoms are, sometimes 4k HDR files play fine in Plex, other times it stutters. Other times, trying to play the file results in a crash, it just goes back to Plex’s main menu. Sometimes, after some stuttering it will still be trying to play the file, but the remote becomes completely unresponsive.
So I tried this fix. Got developer access, but disappointingly, Proactively kill processes was already toggled on. So that was kinda out as a fix, since I’ve been having the issues apparently while it’s been on this whole time. I did set background processes to no background processes.
Results were initially promising. A 4k HDR film played alright for about 45 minutes, with only some microstutters here and there. I thought, it worked! But then the issues reared their ugly head. Stutters became worse and worse, then the remote was unresponsive. That behavior does seems to corroborate what Nvidia said about the Plex app exhibiting excessive memory usage. Hopefully there’s a fix soon.
Also, when I activated Dolby Vision @ 60 hz…I lost audio. Weird. Also had seemingly HDMI connection issues, got visual “white noise” onscreen. Tv definitely supports DV and my Sony soundbar supposedly can pass it. Turned off DV, problems vanished. I dunno. Dolby Vision may not be worth the hassle as I can never seem to get it working right and the differences compared to regular HDR are fairly subtle.
Of course, no such issues at all with my Pro Shield. Both Shields are connected via gigabit Ethernet. when I bought the first Shield, why, oh why didn’t I just spring for the Pro? If I’d have known the Tube was only 32 bit, I probably would have. Damn it. So I guess the options are wait for Plex to provide a fix (a long, lonely road I’ve been down before), avoid playing certain films in my BR where the Tube is, or try to sell the Tube and get another Pro. None of those options are very appealing. smh…
Come on, Plex! You blithely told us all to get a Shield when you tried to kill off PMP for Windows HTPCs. We did…and now this. I mean, seriously.
Maybe I’ll try Plexkodiconnect or something. But, of course that’d mean I’d have to use Kodi
