Definitely! Something that we’re hoping will be ready (for a forum preview, at least) in the not too distant future
Are you expecting all your users to rearrange their servers now and make collections now just because you fixed something that was not broken?
That’s not exactly what I said, and is lacking context. Can you try and make your feedback a little more constructive, please?
Last question, I imagine i should create a Topic if the Summary does not follow the Original Language then ?
Most definitely! Also worth checking if that item has the Metadata language in your language of choice
That is what your answer implies.
Here is some more constructive feedback, which got ignored close to a month now, maybe you could find a minute to read through it, applies to the current behaviour in plexweb now too, minus some bugs i described there.
oh yeah I forgot when I was trying to work out how to get rid of the 10 rows of Recently added on my Xbox etc I found this support page that is no longer relevant cos the “Hub Management” option seems to have gone missing and it was after see this is when I got triggered and went all Karren on Reddit and the Plex forums pmsl
Same settings has you. But Metadata follows the library not the Movies title.
Ah, I think metadata might need to be set independently
ill open another Topic for this thanks.
Not great if its needed to be set on each individual movie.
Cheers! I think most of that article should still apply, but definitely worth revisiting to check. Sometimes it’s hard to keep them all up to date with how quickly things can change!
No worries about getting triggered and reporting. Sometimes it just take a little bit for us to identify what happened (how did this in development thing leak to the public?
), and then formulate a response to users, and get a fix out.
No worries, I know that I can’t do any of that on my Xbox Series X (using the public preview) and my LGtv was the same however I cant say for other devices as I don’t own Roku, Apple TV etc
Ah, that might have changed with the new apps for those platforms. I’ll follow up internally
Sweet thank you. and thank you for clearing up this entire mix up lol
No worries! Always happy to help!
(Also just fixed up that article so it only includes relevant platforms now)
Its still listing Xbox (Client 5.6.1), which doesn’t have the Manage Hubs option anymore lmao
The change may not have propagated yet, or you might have a cached version. Should look like this now.
ahh makes sense lol
I appreciate the communication! I actually like the changes that landed, but I also understand the frustrations from others. Looking forward to the future improvements.
I can’t imagine how this change is good for any user that has multiple libraries.
How is a home page with 10 “Recently Added” lists a good thing?
